wolverine 00 xj
- michigan
In the middle of installing a CSF radiator from DPG Offroad. 2000 XJ, auto trans. The trans lines fit into two places on the driver side of the new radiator, like on the old one. Upper one is a hard line with a screw on fitting. No problem there.
On the bottom, the new radiator has an elbow coming out, as the old one did, and the line that fits onto it has some type of quick disconnect. I got it off the old radiator with a bit of force, but I can't get it back on the new radiator. I'm afraid of pushing too hard on the fitting for fear of snapping off the tube with the elbow coming off the CSF radiator. There is a ridge on this tube, and it looks like the quick disco is supposed to slide on far enough to hook over that ridge, but it won't, and I'm afraid of breaking it. By feel, it appears to have a slightly larger diameter. See pic. Question: can I just cut off the quick disco, pull the rubber hose up, and use a hose clamp to attach to the radiator w/ a hose clamp?
