andrew2516
- New Kensington, PA
As of now I would like to sell the jeep whole so if someone is looking to build a Cherokee this would be a great/cheap start.
The blue tarp is over it because I was trying to keep the interior dry since it was basically in mint condition before the accident and I know some people may want that stuff.
Heres a list of some of the parts...
Suspension
-2x 8" Skyjacker Coils
-2x Rocky Road Spacers
-2x 1.5" Rocky Road Lift Shackles
-Rock Krawler Long Arms(Still have the manual)
-Rock Krawler Track bar and HD bracket
-Rock Krawler 8" lift shocks(3 since one is damaged)
-24" Red Crown performance brake lines
-JKS Quicker disconnects with cables to hold them up
-1x 6.5" Rustys leaf Spring $150 to replace the other
Axles
-HP Dana 30 front with new hubs/joints 297x shafts
-29 spline chrysler 8.25 with disc brake conversion it has new brakes, brake lines, extended e-brake cables, bearings and seals
-Grand cherokee proportioning valve
-4.0L motor that runs fine
-New alternator
-New power steering hoses
-New starter
-AX-15 that is in good condition
-NP-231 with PORC HD slip yoke eliminator
-Cherokee front shaft
-Grand Cherokee front drive shaft that is pulled apart
-Stock Cherokee Rims/tires (one is flat)
It has a newer exhaust...new banks knock off header, new 02 sensor, new cat, Flow master 40 muffler, 2.5" tail pipe. I'm probably forgeting other parts to.
The jeep runs and drives other than the roof laying on your head. Most of the lift/mods only had around 5-6k on them.
If you have any other questions or you want a picture of something directly let me know.
Come pick it up for
$800
Suspension
Axles
-New alternator
-New starter
Come pick it up for
$800
