moparjim1987
- pennsylvania
how do you electronically disconnect the o2 sensor? i work at a dodge dealership so i actually have the tools to fix the thing, just need to know what to do.
moparjim1987 said:how do you electronically disconnect the o2 sensor? i work at a dodge dealership so i actually have the tools to fix the thing, just need to know what to do.
I need to correct you on a few things. Not sure what year your jeep is you are refering to, but 87-90 Renix Jeeps had a special O2 sensor that is a variable resistor. The ECU feeds it 5 volts to the sensor and compares the return voltage 0-5 volts to a reference resistor in the ECU.Flammable said:I have the same EXACT issue you have. Only my issue started when the O2 wires were ripped out or cut by something. After splicing in a new downstream O2 sensor, and replacing the upstream sensor, I have yeilded nothing. I have the FSM for my 1998 Cherokee, in which I looked over and checked every single circut related to the O2 sensors, and other things which may effect the O2 sensor readings. So then out of curiousity to see if it would change my readings at all, we took the cat out, of course nothing changed.
The sensors on a cherokee are supplied 5v, and then from there they send a reading anywhere between .01v to 1v. Mine send 4.96v back to the PCM. I have had two chrylser guys look at it and they have no idea what could cause the problem. We went through and tested the wires leading to the sensor, the sensor itself and the wires leading back to the PCM, we have found no issues.
So with that, your not the only person with the problem. I'm with you, a carb swap doesn't sound like a bad idea.
Anyways, feel free to contact me, I can get alittle more indepth as far as testing things as well. And if you find a solution definitely let me know!
igotanxj said:I have a feeling its not an O2 sensor problem, the PCM doesnt even read the O2s at startup because its in open loop until the engine warms up. Plus the fact that you replaced the O2 and it still has the same problem. I would start looking elsewhere
Ecomike said:Was that 1,2 or 3 wires on the Universal?
It needs to be three wires!
mjma said:4 wires!!! Is that a problem?
Ecomike said:No, only problem is my memory, LOL. I forgot the newer ones added a ground wire. 4 wires is good. I have seen one wire universals at Autozone, cheaper but may vehicle computers do not like them, and will reject them throwing CELs.
mjma said:I'm definitely thinking that the computer isn't a big fan of tthe universal O2 sensor. It is a bosch sensor.....just universal connection on it. I think I'm gonna grab one from the dealer and see what happens.
igotanxj said:why didnt you get the bosch O2 sensor for your jeep instead of a universal?
It looks like you need a bosch PN 13100
