Hello all,
I figure this is a good place to piggyback vs making a new thread on a similar issue.
I have a 1994 XJ with around 110k miles on it. (33x12.5's, long arm terraflex 4.5 inch lift, 4:56 gears, work in progress)
I bought it around 94k miles and have done a considerable amount of wheeling in it already and broken/replaced tons of stuff. I have new springs coming in the mail now to bring my lift back up as it is sagging quite a bit. I also just replaced my transfercase due to my old one exploding on i-10 but on to why I am here today.
Prior to my xfercase explosion I went camping up on the mogollon rim. Heading up to payson I almost overheated a few times and finally did once when climbing the highest elevation spikes on the freeway. Whenever I am on stable ground or going downhill I have no issues (downhill obviously ram air helps). I would put to the top of the hill almost overheating and then it would drop back to normal once I got over the hill. I also tooled around payson and up on the rim plenty without issue, only uphills caused problems.
Since I can drive all around town without issue I figure that widdles the issue down quite a bit.
I have a 2 row radiator that I put in just a few years ago along with doing new hoses. The thermostat was replaced over a year ago.
Because I can drive all around town without issue, I figure it is NOT the thermostat. (I snapped a bolt in the head doping the thermostat in the past and want to mess with that housing as little as possible to not further cause problems) is that a reasonable assumption based on uphill issues only that the thermostat would not cause it? In my experience, bad thermostat means you overheat under any conditions, not just uphill.
The only part of the cooling system I have never messed with is the water pump so I ordered a new one and its in my garage, I plan to slap it on soon.
With a recent radiator, hoses, tstat I figure all that is left is the water pump that could be causing the issue (assuming no cracks in my block and etc)
My temp gauge has never been fully functional so it is extra important I run at low heat levels as when I start to get real hot its usually a surprise and I dont want to have those surprises. I have only overheated once so far and dont want to do it again. My miles are too low to wreck the engine already
As far as I know my regular fan works fine and my electric fan does kick on (not sure when right now but I know it does turn on and go)
Thanks.
