moose.65
- Morganton nc
I have a 96 XJ with a 4.0 and it recently started overheating. It has a newer thermostat the clutch fan and water pump are good. I have flushed the radiator 3 times no clogs and the water was crystal clear after each time. I have burped it a after putting antifreeze (50/50) in it. It has no loss of power no smoking and the oil isn't milky or anything. I have also cleaned the radiator with coil cleaner so that's not a issue
Thanks, Brian
Thanks, Brian
