shimmy
- seattle, WA
so a guy is selling his jeep for $300, the only problem he says is that it overheats...could i get by with just replacing the thermostat?
brandon
brandon
it is a closed system1989laredoxj said:What year is the jeep? Is it a closed system?
martin said:The life of a radiator is 7 years, anything more is just gravy.
i already have a rigged XJ... this is just for some extra cash, or DD. i was going to fix it and resell it, or just part it out. what is necessary to convert to an open system? how much will it cost to just replace the thermostat and radiator cap?1989laredoxj said:Are you going to get into lifting it and throwing some bigger tires on?
If you are I put bigger tires on my jeep and started having really bad over heating problems. I upgraded to the open system, pretty easy to do. Now no over heating problems at all
shimmy said:how much will it cost to just replace the thermostat and radiator cap?
