I got a chance to test the O2 sensors today.
Observation 1: 3 O2 Sensors Tested OK
B1S1 & B2S1 & B2S2 both tested out OK.
Voltage readings at idle were as expected (between 0.1 and 0.9 volts, cycle roughly every second) - although a bit on the high side.
At 2K rpms it still fluctuate a bit as I originally saw on DashCommand, on the high side.
All grounds tested at a little above 1 ohm, and the heater wire showed full 14 volts.
Observation 2: 1 O2 sensor behaving differently.
I noticed though that B1S2 behaved somewhat differently.
Although I got a voltage reading similar to the other 3, I couldn't get the heater wire to register any power and none of the grounds measured any resitance.
I don't know what effect this has, being it that it's a post mini-cat O2 sensor.
I also don't know how I could have measured any voltage on the sensor reading itself if none of the grounds measured any resitance.
But, my overall belief is that the O2 sensors are OK, especially since replaced within the last year.
Back to the Cooling System Condition
I have noticed within the last few days, that my cooling system is behaving "better".
If I get stuck in traffic like today in 85-90 weather, it will creep up to 220 after a few minutes but as soon as the aux fan comes on it cools back down to 215-216 within another few minutes.
Other than that, it's at 210 while moving slow or fast - no higher.
Although it seems to behave "better", I'm still convinced it's not up to snuff.
I'll keep checking things out...fuel pressure, vacuum leaks, exhaust system & manifold leaks etc.....stuff that I believe may be throwing off the O2 sensor readings as they keep reflecting a rich system with very negative LTFT's.
Question for all:
As I mentioned before, I added roughly a few months ago 6 new reman Bosch 4-pin hole FI's. I don't know what the flow rate is or any of the specs. I bought them on eBay, I believe I had found this seller through someone else's post on
. Would this for some reason throw my ECU off, thinking it's running rich (because they are 4 versus 1-pin hole, or maybe because flow rate is potentially higher)? Just a thought.
