It's a thermistor. It increases and decreases resistance with temperature variance. As long as it is two wire it would be a cut and splice. Just remember accuracy depends on how close the resistance is at a set temperature to the oem sensor.
Look between the front "frame rails" in the center of the vehicle by the font bumper. There should be a plug which looks like the factory fog light plugs there. That's for your temp sensor.
My 98 sport had the wiring there for the temp sensor when I added my overhead console, so if yours is a 97+ it should be there. I can't speak to 96- though, but the info is on the board, search around. I got all my info for my OHC install here.
