so the ohc is installed and all the lights are working properly.
obviously nothing else works because i don't have the black plug.
i got an extra plug and all 3' of wiring attached to it.
i will now hard wire this plug into the jeep.
i need help on knowing what each of the 5 wires is used for.
1. BLACK w/ white stripe
2. BLACK w/ green stripe
3. ORANGE w/ black stripe
4. BLUE w/ orange stripe
5. PURPLE w/ green stripe
purple with green - one of the temp sensor wires, detailed this on page 1
orange with black - should be the display dimmer signal if I recall correctly
black with green - I think this was logic ground for the compass but I'm not sure
black with white - either a ground or ignition switched 12V, not sure
blue with orange - sure it isn't blue with red? I think this is for the parking/interior lights, again, not sure
I'll see if I can find the reference I used to hard-wire one for a friend of mine.
seems I switched the orange/black and blue/orange (probably what he lists as blue/violet, I seem to recall mine being either blue/red or blue/orange as well.) Your black/white wire is probably actually black/light blue and is the other temp sensor signal, I think. I got the black/green wire and purple/green right.
Overhead Console Front Wiring Harness
pink-1 -- constant power for forward map lights
pink-2 -- constant power for rear map lights
black -- constant ground for map lights
white/black -- switched power for console computer
black/green -- constant ground for console computer ("logic ground")
yellow -- switched ground for dome lights
violet/green -- temp sensor signal
black/blue -- temp sensor ground
blue/red -- headlamp signal (for brightness control)
orange/black -- dimmer control
