JEEPZZ
- In front of my PC
The XJ brackets are interchangeable, pre97 & 97+. The XJ bracket will also work with the other consoles you mentioned (even better since the hooks are offset to allow for full engagement).
The only differnece is you'll need to spin the bracket around so the 'hook's are positioned at the opposite end.
Notice the pre & post 97 XJ brackets are identical, only where it is marked "forward" (FWD) is different. Just spin it around to match whichever console you are using.
While we're on the subject, the temp sensors are also interchangeable.
The early style is no longer available but just grab the newer style from a 97+ XJ or ZJ.
pre97 on the left, 97+ on the right
