i know there's something wrong with this engine. the XJ has been a lemon since day one. i won't list everything, but under warranty i had 2 transfer cases, front axle, fuel pump, PCM, TCU, airbag module, wire harness, alternator, at least 8 oxygen sensors... so i'm not suprised that this is happening. it has 65k on it. i checked my fluid levels the day before going off roading, the levels were fine.
i talked to the other people who were driving cherokees that day we went off roading, none of them reported any abnormal levels.
now, i think i have a bad head gasket or something. the coolant in the overflow tank turns black within about 300 miles of me driving it. i used to change the oil and coolant every thousand miles, now i just don't care. i've been changing the plugs every oil change since 60k, when it went out of extended warranty. owned it since new, i've got a pool set up with my friends as to when/what mileage it'll finally blow up.
i didn't think about this until now, but it could be a ton of oil in the coolant, like a quart or so, causing the overflow bottle to be full. it isn't knocking any louder than usual, i guess i'll have to check the plugs and see how bad they are.
i've been running the 1.28$ autolite plugs because i buy them so often, gapped at .035.
when i checked the coolant level, the thing was cooled down, both times. before and after the off roading trip, on level ground both times.
it smells like coolant all the time, but its been doing that since about 40k. the 5 star dealer even wrote on my service sheet that the smell is "normal for this vehicle".
if i'm smelling it, its probably getting out somewhere.
any more ideas?
