- Billings MT/Rapid City SD
89 4.0 XJ
I have done the cnversion to convert my closed system into an open by installing the Moroso Filler neck into the upper radiator hose. The problem is over a period of time I loose a pretty good amount of coolant and the Jeep starts to overheat(obviosly). I belive most of the coolant is leaking out through my expansion/reserve tank and am looking at how I might fix this.
I have the filer neck in the upper radiator hose. The small overflow hose runs from the neck to the stock pressure tank. The inlet on the bottom is where the coolant come sin at and the upper outlet is the overflow hose. Does this sound like the correct setup? I am thinking of running the overflow hose to the bottom of the tank so it would take some pressure before the coolant would overflow, would this help at all? Any insight would be appricated.
