like it says it only starts in neutral. It wont start in park. Its a 96 XJ with abs (dont think it matters but just in case lol) Is it the neutral safety switch??
As birchlakeXJ posted it is probably the NSS, and it should be cleaned and lubed with dielectric grease, but it could very well be the shift linkage needs adjusting.
NSS mine does the same thing but my is not all the time. if you put it in neutral and then throw it into P mine starts in park. other than that i start it in N
Thanks for that link Joe! I just bought a 95 country with a "bad starter/seized engine" for $200 off of craigslist and determined it was the nss by running a ground to the starter relay, thus bypassing the nss. I'll take it apart and give it a good cleaning.
Dad refreshed the NSS(while I was yanking wheels and brakes). One of the springs was stuck in a compressed state. We plugged her in w/o mounting it and got the jeep to start and then he twisted it and the reverse lights came on. I've been wrenching on manual XJs all these years, so it was an interesting learning experience.
Hallo. I did the job too. But I was so unlucky to loose a tiny spring. LOL
I drilled a bigger hole and filed out the little copper contact. Then used a piece of coil from a ballpoint pen. It works perfect ! :dunce:
