- Maurertown,Va.
The Ol,96 has turned over 400,000 miles,,so now what? Motor still uses no oil between changes(3000) oil pressure at speed 50 and at idle(hot)20 psi-factory guage,
Yes it has valve train noise,Vacuum at idle is 15>17 inches with a little needle flutter.
Nothing inside engine has been changed,valve cover never been off in the 360,000 that I have had it.
How long can they go ?
Even though motor is still good the plan is to replace with a Jasper Class 1 next week....just for piece of mind. I hope replacement will last as long.......
