- Burbank
For approximately 6 months, my oil pressure has been slowly going down. When I first got the jeep a year or so ago, hot idle was around 30-40PSI and cruising was 50PSI. Today, hot idle was 5 for a few minutes, then the gauge dropped to 0 triggering the check gauges light. A little more RPM got it to register again. Cruising today was anywhere from 20-40PSI; it kept moving all around while driving the same speed. I've been reading up on this and it's almost certainly because my Jeep has 180K on it and the engine is just starting to show it's wear :repair: I've also always had a loud tick coming from the top end - which I'm sure has to do with a lifter. More concerning to me is the slight knocking I've started to notice at idle. What's more strange it that it only happens sometimes, hot or cold.
I was thinking of replacing the oil pump with a new OEM one (seems that HP and HV pumps aren't worth it in the 4.0l) to *see* if that even makes a difference, but am concerned it may just be a waste of time/money as it seems that my engine is just old and worn out. A new oil pump isn't going to fix that.
I'm hoping to get some feedback on what others have done when their jeeps have exhibited low oil pressure. What makes sense to try before I start taking things apart. *SHOULD* I go for a new oil pump for the heck of it? Is is better to just rebuild it and be done with these issues?
'01 XJ, 180K, 10W-40 (per manual), oil replaced every 3K-7K (maybe that's the problem :eyes since I've had it.
