grundan
- N. Alabama
does anyone have a oiling diagram of the 87/4.0
my haynes manual does not have it, also searched.
I'm about to pull the head tonite on this 87, it is not oiling on any of the cylinders (top side/pushrods/rockers). engine runs quite, 40+ lbs oil pressure
drained the oil last week and poured 5 gallons of kerosene in the engine via the valve cover. let it sit a day, turned the engine over with the coil wire off.
drained kerosene filled with oil and new filter....nada
still no oil thru pushrods
btw, I have replaced 2 rocker arms and pulled all the pushrods and cleaned them thoroughly before the kero treatment.
I hate to tear down this motor and rebuild it for a blocked oil passage.
any more tips ? TIA
any more tips ? TIA
