offroadordnance
- Florida
The valve tip edges may have burrs on them that can damage the new seals when you install them. If there are bad burrs, you might want to knock them down with a jewelers file leaving a slight chamfer on the edge only. Of course, collect any particles to keep them out of the engine.
If you hit the locks with penetrating oil like C54 suggests, you may want to squirt the stems to loosen up/ remove any varnish above the seals.
