xcm
- Southern Oregon
I understand the benefit of moving the switch from a hot to a grounded wire, but how does it cut down on wire used? If you're running the switch to the cab it seems that the same amount of wire is used, whether its switched hot or ground.
On switched hot, you need to run 2 positive wires to your relay. granted one can be from your dash panel hot, but you still need 2 hot wires. With switched ground, you only need 1.
The other benefit, is if you happen to knick a wire, or it comes loose, etc, its much better for this wire to be a ground than a hot, a ground wire wont start a fire, it'll only turn your accessory on.
