- Houston, Tx
Did the non-disco conversion to my disco 30 back in sept to get 297x shafts. Also installed an aussie locker at that time. Did the dremel out the housing trick.
A week later, my rt tube seal was leaking and leaving a cd sized puddle on occasion... i pulled it apart, replaced the seal again, and I thought I was ok.
Tonight, I see the same puddle again. I'm assuming I screwed it up when doing the seal conversion. What are my options here? is there a slightly larger seal that might work? Can I band-aid it with tube seals? Should I just get a new non disco housing and get it over with?
