phxZ31
- Phoenix AZ
1) My feet vent setting and my mix-door don't seem to be working properly. With heat of full blast, sometimes I get blasts of chilly air, and the feet vent doesn't seem to be fully engaging, as about 50% of the air blows out the defrost vents up top.
2) Idle speed slowly oscillates up and down by a hundred RPMs or so. Occasionally the engine will vibrate for a few seconds and the RPMs will move up a couple hundred RPM, then it drops back down and stops vibrating.
I suspect a vacuum leak, but I'm not sure. All of the vehicles I've been familiar with have all used a MAF to meter intake air, and so vacuum leaks cause all sorts of unmetered air problems. The Jeep doesn't have one, so I'm assuming its got a MAP sensor in the intake manifold. Will the Jeep idle funny and get poor gas mileage if it has a vacuum leak? It would make sense, since both of these issues popped up at the same time, but I'm just making sure.
