Rod Knee
- Grand Jct., CO
What you lose with a NP242 and auto lockers is the ability to run the full-time on dry pavement, since the fully locked axles don't allow the t-case to differentiate as it's designed to do. The full-time is really handy for wintertime driving on mixed snow/ice and dry pavement roads. So as long as you don't use it on dry pavement in full-time, you're fine. It's designed to be used on dry pavement and other mixed conditions without having to shift back and forth, like an all-wheel drive car or SUV that you see so many of these days. Once you remove the differentiation from the axles by locking them up, you don't allow the full-time t-case diff to operate as it was designed, and it will fail if you do run it on high traction surfaces like pavement or slickrock.
Go with a selectable in the front, that's what most of us with the 242 have done. If that's not realistic, then just don't use the full-time.
In your first paragraph you seem to be saying that even an auto locker in the rear could cause failure of the 242 if the jeep is driven on hard surfaces. Then in your second paragraph it sounds like you are saying that its only the front that should not have an auto locker. I would appreciate a clarification since I have a 242 and am considering the pros/cons of various traction aids. Thanks in advance.
