np231 what ones will work
90xjwheeler
Dublin
I just blew my np231 out of my 90 5spd laredo 2drlast weekend and need to replace it. I was wondering what other years I can pull another one out of? Or can I rebuild mine with better internals. I havent torn it apart to even know if that is an option but I need to install my sye so either on mine or another tcase.
Thanks in advance
Tim
I don't recall the spline counts offhand, but check your transmission case to see what you've got. If the transmission has a longwise join down the case, it's the Peugeot gearbox, with the early spline count. If you don't have that longwise join, it's the AX15 - which is a better gearbox, and takes the later spline count (and expands the availability for you.)
I can't say for certain, since 1990 was the transition year. I think they switched in August, but the most reliable way to tell is to crawl under there and have a look.
Essentially, you can use ANY NP231 tcase as long as your input gear isn't toasted - if it is, you'll need one with matching spline count...
5-90
