Oaktown95XJ
- Grand Traverse County, MI
I have the same problem in my '95 XJ (no turn sigs, hazards or brake lights). Can't get good coinciding info though. Haynes manual says one thing, official '95 D/chrysler service manual says another. Both say I should have a fuse in the fuse block at #8 position, there is not one there, never has, in fact slot for fuse only has female fuse clip on one side not both, so there could never be continuity there. Haynes says I should have a turn signal flasher and hazard flasher on the fuse block. owners manual and official DC service manual say there are no flashers on fuse block, rather a combo turn/hazard flasher is built into a relay in the relay center to the left of steering column. Rarely, they will work, but it is very rare (indicates to me a short or bad ground somewhere. I suspect it is the combo turn signal/hazard switch, but have not tried replacing yet. The lack of fuse in the fuse block really fazes me out. Recently, (in the past year and a half) had a headlight harness connector melt (the one to the fender side of airbox under the hood) dont know if that may have had anything to do with it. Also, year before that ignition switch in steering column went bad, (corrosion-burned up). Both are now fixed, but now the light problem, could there be a connection? Anyway, I have the plastic surround off the steering column, do I really need to disable the airbag like service manual recommends just to replace the turn/hazard switch? I really think it is that switch because wipers dont always work either, which the service manual says wipers have some connection in that multifunction switch.
