joe_peters
- Grants Pass, OryGun
Not 12v just 0.12v
Unless your meter is set on the wrong scale you have a problem, you need 12v.
Not 12v just 0.12v
So it's not getting juice from the ASN relay. I think you can try moving the relays (that look the same) around in the big fuse box under the hood. If that doesn't help, we have to check for juice feeding the ASN relay. Sometimes just uplugging and replugging the relays reestablishes good contact.
I don't here anything in the run position.When you are checking for voltage at the coil, and listening for the fuel pump running, is this while the engine is being cranked? Because the ASD only sends voltage to the coil and pump for a few seconds in the run position.
I want to thank everyone for their help!
Sadly after a compression check the number four cylinder has suddenly lost compression :soapbox: so no going any further i guess!
Any one interested in a Jeep with a good body and bad motor?????
Thanks Again
Joe
