DeftwillP
- Round Rock TX
I've had a gojeep harness for some time on my jeep with no issues. Recently I lost low beams and just assumed that the relay was bad. Both of the fuses in the harness were ok. Went ahead and replaced the relay to no avail.
I did my due diligence in searching first here on . Went ahead and replaced the headlight switch and checked the plug behind the driver's side light and still nothing.
I know that both the high and low filaments are good. I can switch the "signal wires" from the stock headlamp plug to the relays and manage to power up the low beam relay when the dash says my highs are on. But then when I switch to low beams, I don't get highs.
Any thoughts?
Any thoughts?
