winterbeater
- Royal Oak, Michigan
If your getting sparks when you jump from the big wire at the starter to the little terminal on the starter, she should crank. Are you sure your are holding the connection good enough? Hold it firmly for a couple of seconds. It will arc until you hold it firmly enough. If that doesn't hapen, pull the starter and try jumping it next to the battery with jumper cables. Positive on both big and small terminal, negative to starter body.
