winterbeater
- Royal Oak, Michigan
1999 Jeep Cherokee 4.0L, Vin S, Eng Cfg L6
Customer Concern: Odometer displays no bus. Crank no start, died while driving.
Tests/Procedures: 1.Test powers and grounds at the Powertrain Control Module (PCM) on the C1 connector. Pins 2 and 22 are power, then check pins 31 and 32 for ground.
2. Next, test the 5 volt power supplies at pin 17 of the C1 connector and pin 31 of the C2, or middle connector, for shorts to ground. Sensors on the circuit are the Camshaft Angle (CMP) sensor, Crankshaft Angle (CKP) sensor, Throttle Position Sensor (TPS), Manifold Absolute Pressure (MAP) sensor and Vehicle Speed Sensor (VSS).
3. Unplug the sensors on the 5 volt power supply, one at a time, while monitoring the 5 volt supply.
4. When the shorted sensor is unplugged, the PCM will wake-up and scan tool communication will return.
Potential Causes: Camshaft Position Sensor (CMP)
Crankshaft Position Sensor (CKP)
MAP Sensor
Oil Pressure Sender
Wiring Harness
I would test out per wildman's post. Do you have a multimeter? If not, you need one as a companion tool for your XJ.
