bakerboys
- eastern n.c.
Have a 1989 laredo 4.0 xj automatic stock 220,000 miles
Sometimes when you crank it it takes a while to start and then shuts off
keep cranking it and it will start and shut off then it might crank up and idle fine till you touch the gas then cuts off then it may crank up and rev like 2500 rpm and stay there then you cut it of it might crank and run normal it is wierd because it is not the same thing every time i did look for vacume leaks this jeep has lots of hoses
any one had this problem before and might help me find a solution Thank you
