The problems i had with mine was the drivers side LCA, both bolts were seized, brother ended up cutting em out. other than that, lift went in pretty easily.
Great! Almost everyone talks about breaking the bolt free. I am past that. Only one won't come out and it turns freely. It is the upper bolt in the rear. What is the configuration of the nut in the unibody? Is it a nut spot welded in or something else. Does any one have pictures?
If the leaf spring nut (in the unibody frame) breaks loose...it will suck. You will have to cut the bolt to get the spring off and do the following. Yes i sprayed it with PB before hand....
Cut leaf spring bolt/nut was spinning freely in unibody frame
Cut unibody frame to get to nut
New plate with nut welded to back side ready to burn in.
hey sjx40250 (and anyone else out there doing the leaf spring upgrade thing) I just had a fun time trying to get mine out. I had the same old problems with the bolt rusting to the sleeve of the bushing, and I had to cut them out with sawzall. I also broke the rear shackle to frame nut from it's weld on the passenger side. I had to cut a hole from the top to access the nut thru a hole in the frame. I know that sounds confusing but when you look down from the top (from the hole you cut ) the nut is seen thru another hole in the frame. These nuts are not 21mm like the heads of leaf bolts and the nuts on the shackle to leaf bolt. I finally cut this one out after struggling to fit a socket over this nut which was at least larger than 22mm (largest socket I have). After visual inspection it appears to be 24mm because it is a locking nut. I cannot verify the size but it is definitely bigger than 22mm. I hope this helps, and maybe someone will chime in with the actual verified size of this locking nut.
I have a 97XJ Sport and I am installing a 3" OME lift kit, and will be a member soon. This site rocks!
