BRIANHO13
<- Yum Chocolate
- Spring, TX
I was contacted a while back by a member on here (XJ Stryker) who needed to fix some rusting out rockers, this is what I came up with.
1/4 steel formed to the rocker that sits flush with the door seam and with the pinch seam.
Here is what we were working with.
The piece that attaches the front fender to the pinch seam has to be removed.
Put it in place and weld it in.
Beat on it real good with a BFH and even used the hi-lift on it. The 1/4 spreads the load out and should be able to take some pretty nasty hits.
Whether it's ground clearance or the stock appearance you want to maintain, this is what you need. One set weighs in at about 50#
As some of you may know Dirk Pitt (Adam) and myself are starting an offroad business and will be releasing a few more NEW to the XJ products. Please contact Adam or myself if you are interested in purchasing a set ($150 / set).
Please keep an eye on the give away forum in the next few days we will be giving some goodies away.
We will start taking orders and giving stuff away as soon as the state approves our paperwork…..should be anytime now.
