moneypitxj
NAXJA Member #565
- york, pa
ok i got a problem w/ my x-fer case. i installed the sye w/a woody. when i put the junk in 4lo it wants to pop out if i can even get in to pop in 4lo. i was told it probably is the mode hub in backwards.
well yesterday i tore it apart and there is no way to put the hub in backwards because you couldnt get the snap ring in that way. so that i had that in right. also i measured the shift rail and it is a 1".
so is there anything else i can check out because i am at a lost and tired of tearing this junk apart?
