RCP Phx
- Phoenix,Az
The biggest issue with stacked cases is that the already short driveshaft becomes even shorter!Where would you even use such ratio's.My sons tc is 4.7:1 and thats almost to low.
i'm running ax-15, 33's, 4.56's and 4:1... that's gotta be near spot on gearing to 35's and 4.88's.
4:1 does make gear noise.
In 2wd I only notice it if slowing to a stop and downshifting, otherwise I never hear it. If it does make noise all the time it must get drowned out by the super swampers.
In low range it is noticable at about 1200rpm, and gets louder as you gain more rpm... thankfully, there's rarely a need to run any great distance at more than 1200rpm.
And, gear whine doesn't bother me anyways... they're gears, they make noise.
4:1 is not too low, I make use of 1 through 4 when in low range... If I need more speed than 4th at 12-1500rpm, there is a really neat lever beside the tranny shifter that allows you to go to high range. Amazing. On less technical terrain, with 4.56's and 33's (or 4.88's and 35's) I often find high range is plenty capable. which pretty much means, I don't run low range in 4th with 2000rpm when high range and 1st will surfice. Again, 1 lever allows you to shift in and out of low. Not a big deal when you shift your own gears anyways, but I can see the auto folks not liking it.
My .02
