bhicks
- Forest Falls, CA
Looking for some stock XJ, TJ, or ZJ rims. I like the later model Classic rims but right now I'm not too picky. I just found out that my Suzuki SX4 has a 5 x 4.5 bolt pattern. I also will be putting on a little 2.5" lift and skid plates. This last winter was hard on my little zuk. The horrible ground clearnace caused me quite a few issues in the deeper snow. My factory plastic front skid plate shattered. The lower part of my rear plastic bumper has some damage now as well. I plan to put the lift on and run a taller snow tire. I would like to keep my stock tires and rims to run the majority of the year and then toss on a set of winter tires and rims during the cold months. What I would like to do is test fit a XJ, TJ, or ZJ rim. The SX4 guys are saying I need some type of hub ring to fill the gap since the center hubs don't match. Not really sure what they are talking about or if that is a sketchy thing to do. If you have a stock rim lying around I would really appreciate you letting me borrow it for a while to get this figured out. If they will work with no safety issues then I will probably buy the full set from you if you have a full set. Hopefully I can find someone semi local to the Yucaipa area.
