My 95 xj typically gets between 18-21mpg, and the best I've done is 26mpg on one trip (hand calculated) where we were driving about 55-60 the whole tank non-stop in summer.
I switched from crappy tires (brand was Winner) to Goodyear Wranglers (OEM size) and mileage went down almost two mpg! These tires are noticeably heavier (when rotating and they slowed down my low speed acceleration).
Spark plugs: I swapped to some iridium plugs and gapped them accordingly, then a month later tossed a MSD ignition in it. They both helped with mpg and idle. I recommend them. I even put them on my 95 YJ as well.
Injectors: I have bought new OEM injectors when I bought this Jeep, then two months later swapped to the Neon ones, and I picked up about .5-1mpg and gained a super smooth idle. It didn't feel any faster.
Trans cooler: I used a Ford 6.0L diesel trans cooler, Earl's AN fittings, and Aeroquip hose from the trans to the front. I haven't had a leak or issue ever. I'd also recommend an in-line filter header for the trans fluid (so you can change it like a oil filter for an engine). I typically do this on my vehicles (even though I haven't done it on this one yet) and it keeps the trans fluid Super clean. Way better than the little pickup filter.
If you're taking the header off, port match the head and header. Lay the gasket over the head, spray it with something to mark the location, and grind away. Your EGTs will drip slightly and your peak power will go up ever so slightly.
I'd also take apart the throttle body and clean it while you're there. The idle control likes to get cakes with blowby gasses.
Oh, and the last thing, retorque your head bolts.
