Hoghauler
- Modesto ca
Well after 3 long days I got the lift finished today. Other than the front brake lines and cutting the old lca mounts off. The rear brake line already had a extended stainless line and I relocated the front brackets to make it drivable I just can't be flexing my suspension out until I change them. I still need to take it and get an allignment but it drives really well other than the steering wheel not being straight. All in all I think the part that went the best was the hack-n-tap. Very straight forward and if you use new sharp drill bits it will drill very easily. I was dreading this because there has been some reports on here about having to split the transfer case and take the output shaft to a machine shop but definetly not the case for me. Took probly 1.5 hrs start to finish. Well worth the money.
Still more to come as money permits.
