YELLAHEEP
- Littleton, Colorado
I'm gonna be moving my parts operation from that pit of a storage lot to a much nicer location a short distance away sometime during the week of the 21st.
So, I'd love to thin out my inventory a bit rather than figure out how to pack it all up. If you guys are needing anything, PM me and I'll check to see what I've got.
Among the "stash":
31/10.5/15 MTR with 20% or so tread mounted on an alcoa polished aluminum style wheel. Lug pattern is 5 on 4.5, wheel is 15x8 and in near new condition. $50
Several "new" never used full size spares in 225 and 235 sizes mounted on steel spoke wheels. $25 each
Tan and gray pre-'97 center console with mounting brackets $20
Lt gray '97+ center console with bracket $20
Agate '97+ center console with bracket $20
'97+ fuel tank with pump assembly $30
Several grill center sections for all years, white '97+, Forest green '97+ $10 each.
'97+ AC compressor, condenser, evaporator and lines.
Renix era brass 3 core radiator, just needs minor seam leak fixing - core is in great shape, easy fix at a rad. shop. $40
Tons and Tons of sensors, switches, power window motors/tracks (driver's side '97+ might be out of 'em......)
Electrical system spares "kit" - I pulled all the fuses, relays, bulbs and whatnot from a '97+ and put it all into a zip lock. Great for your trail fix kit! $15 **SOLD**
Several gauge clusters for all years. $20 - $30 each
M.O.R.E. 4.0 motor mounts, used only for a month or two. Gold anodized metal. $20 **SOLD**
Motor mounts that closely resemble Brown Dog mounts - use LCA control arm bushings so they're rebuildable. Black powdercoat. $30 **SOLD**
'97+ rear hatches - 1 white, one red. (red has key scratches) $40 each.
Rear hatch interior panels. I have 2 pre-'97 in gray, 1 pre-'97 in tan, 1 '97+ in light gray. Early models $10, '97+ $20
Numerous pre-'97 tail light assemblies, front turn and marker lenses. $5 each.
Rear view mirrors, all years. Early $5 each, '97+ $15 each
Light gray front and rear seats for '94-'95. Great shape. $40 for the set or $15 each.
'97+ rear cargo sill trim (the part that runs along the bottom edge of the hatch opening) 1 light gray, 1 tan $10 each
Nice black tilt steering column from a '91, complete with key/lock $40 **SOLD**
Rack sliders, cross bars, end caps for most years.
Several rear hatches for pre-'97. Blue, desert sand, $10 each.
Glass for all years, all doors, all fixed and wing windows, rear cargo and rear hatch. $15 - $25 each for windows and hatch, '97+ rear glass $45
Doors for all years. $30 each.
'00 4.0 cast exhaust header set and down pipe. Get rid of that cracked factory header. $45
Several 8.25 29 spline axle shafts. $20 each
Several 297 D30 shafts, some have ABS rings, but will fit all applications. $20 each. **ALL SOLD**
'97 HP D30 with 3:07 gears, 297 shafts, very recent unit bearings. $100 **SOLD**
Several 5" 3-way speaker pairs - Kenwood, Sony XPlode and others. $20/pair
4.0 clutch/pressure plate/flywheel with low miles. $80
Lots of other keerap.......
I'd rather sell it than move it! :thumbup:
Among the "stash":
