Has anyone with hydraulics mounted the ram to the diff cover? I have a 1/4" plate steel cover from Bluetorch so it would be easy to weld to, but my question is will it leak? Anyone have experience or problems with this?
TIA
mattk
I'm working my 44 front now and have sort of the same question. Where to put the RAM. With a full detroit up front seems a ram would be the best solution, If one can get it squeezed in.
Yeah that was my other option. My steering will be a little different. It will be an inverted T setup using TREs (don't get me started on heims). I have a d44 with a damn near identical trac bar mount. The drag link will mount to the tie rod at a spot right in front of the spring on the pass side. This is mounted on high steer arms. I may end up mounting the ram just under the tie rod.
Is that the redneck ram setup? Are you happy with it?
mattk
