RockRod
- Janesville Ca
JKS 9603 $25 Front shock bar pin eliminator
JKS 9601 $25 Front Upper Shock Conversion
JKS 9604 $25 Top Rear Shock bar pin eliminator
$7 Each Shipping or $7 for all three All brand new in boxes......
JKS OGS 125 $150 plus shipping, brand new.....
This front trackbar will allow you to easily center your axle under your Jeep. One turn of the adjuster shifts the axle by approximately 1/16 inch at a time so you may fine tune your axle center very precisely. A perfectly centered axle is important to have for proper steering and "Quick Disconnect" operation.
The body of our trackbar is made from 1.25" x .156 DOM tubing, bent to proper angles for various lifts. A rebuildable "johnny joint" is used at the frame end, which also happens to be greasable. A tapered sleeve is then provided to fill the remaining taper. At the axle end you will find a zinc plated adjuster using the factory OEM style rubber bushing to reduce bushing "noise" transfer. The body is then flat black powder coated for corrosion protection.
5- Never mounted Custom Hammerite center caps for XJ bolt pattern
Have Trail Rated Factory Hard stickers in the center(sell foe $28 by themselves usually or more, the stickers) All 5 for $75 o.b.o plus shipping..
MSD DIS-4 Used, like new condition...For any Distriburtless XJ Not sure on year, worked on my 01' Retail for $450 plus plus the price of Tach adapters
Sell for $250 plus shipping And will throw in Tach adapters.....
Let me now, can take Paypal............... aperwork
