- sacramento
I've been reading more, and it seems like the 28 cam gives more torque and earlier in the RPM range, that seems more attractive to me. Its not a DD, but it does get driven to the trail and sometimes to work while in working out bugs or breaking things in. I just wonder if I can get away swapping in a 28ad cam now and just leave the cam bearings as they are ?
from this thread:
The Mopar cams do improve power over the late model cams even though the duration is less 'cause as I stated earlier, the overlap is less and thus the dynamic compression is more. Compression ratio calculator from Jeepstrokers: http://www.jeepstrokers.com/calculator
The dynamic comp from the renix/obd1(87-95) installed -8* is 6.36:1, installed straight up 0* is 6.82:1. The dynamic comp from the 96-01 cam is 7.47:1. Install the Mopar 28 straight up and it is 7.73:1. Install the Mopar 29 straight up and it's 7.56:1. So with the 28 you have more low-end torque and have it earlier, and it lets more air in with lift at .43" compared to the 87-95's .424" and the 96-01's dual pattern .408in/.414"ex. The downfall with the 28 is that the power drops 500rpm shy of redline(no biggie).
from this thread:
