- Austin, Texas
Planning on taking off the valve cover this weekend time permitting and spraying the valve train, push rods, and lifters with MMO to address my lifter tick, per Ecomike's advice.
Any tips on anything I should do or check out while the cover is off? I do have one CCV valve that is leaking slightly, so I'll probably replace that while I'm at it, but this is the first time I've had a look at the top end.
Ecomike: Do I need to change the oil after the overnight soak?
Thanks, asy
Thanks, asy
