Matt S.
- Fresno, CA
Richard, I agree with the motor. I will probly be doind just that because there is NO other motor that has the low end power and RELIABILITY that is has. As well as the AW4. From what i can remember, you have the RENIX motor correct? Well, I just sold my jeep and it had the RENIX, the engine bay makes me uncomforable and could cause a problem with the tubing work that i HOPE will be done.
NO, i do not have the truck already. And I WONT be buying one until I finish my schooling here in Phoenix. But I plan on getting my entire designing done with math and all. Then begin wiht buying the pieces to build. I have a TON of time for this.
Basically, If you were to cut everything from the firewall forward off and everything from behind the cab off, thats what i am looking into. So I want to have a semi-prerunner body styled LOOK built for rockcrawling. I am thinking that if i can build a full chassis and incorperate the body into it, this would be very benificial for CA laws and such. And because I DO want to drive it on the street to wherever I need to go, I have to pass CA emissions and all that.
Full width 60's are probly what will end up under it because of parts availabilty and reliability. And with at least 38s, probly 40s, shaving is going to greatly help to keep up with the smaller axles.
For the lightwieght ideas, where i get concerned is WHERE the wieght is going to sit. If it is mostly tubular, most of the sprung wieght WILL be in front of the cab. Somehow i have to figure into the design wieghts to creat a blanced vehicle wieght, so the suspension will work much easier, and HOPEFULLY be balanced as well.
THANKS
MATT
THANKS
MATT
