- Southern Maryland
JB Weld will work if you can give it a surface to hold onto and if you are able to completely encase the damaged area. If its just a pinhole maybe you can drill it out and spread epoxy over both sides so that it won't move. If its actually a crack, probably won't work unless you cut the whole crack and fill it.
