ChevelleSSLS6
- Grand Rapids, MI
fuel filter?
fuel filter?
Then it seems like it's back to the heat soak issue. As suggested earlier, next time you shut it down after the hard use, open the hood. See if it helps. If it does, add the fan timer.
Sounds like you got pretty unlucky, mine's been nothing but reliable even though I was running on ultra worn plugs/cap/rotor for a while. It idled really rough but *always* ran. The only time it has failed to start properly for me was in 20 degree weather after completely flattening my battery, with really dirty battery connections (now fixed) and the only set of jumper cables available turned out to be cheap chinese crap with 16ga wire inside extra heavy insulation made to look like the wire was thicker.
There's probably something really simple you can do to it to make it just as reliable as everyone else's, don't give up just yet...
I believe there was a TSB for this - to install a heat shield and possibly also to recalibrate the computer.
some have wrapped their injectors with that heat-shield tape.....
:nono: Trust me, i'm never buyin an 00-01 xj again. I almost bought a 2.5L 5spd tj two weeks ago cuz i was fed up with this.Problem is that most reports are that these fixes don't work. Just running the efan to cool it down after shut-off.
As far as the crappy 4.0 rant, I feel about the same with the 0331 head crack problem. Run forever, 300k miles, etc. etc. Yeah sure, just don't get a 2000, 2001. Whoops, too late. Maybe my next one.:flame:
Just did some digging (I'm not too familiar with XJ fuel injection, figured it was about time) and from what I'm reading, the problem is that the fuel in the fuel rail boils and vapor blocks due to the heat from the minicats... and that the problem didn't exist on older generations because they had the fuel pressure regulator at the far end of the fuel rail, and a fuel return line. I guess this lets the pump break the vapor lock? Any reason a 2000-01 XJ couldn't be retrofitted to use this setup? I'm currently running a 97+ fuel tank and pump on my 96 with no issues, which is a little odd now that I think about it, because it means I have a pressure regulator built into the filter at the pump as well as one on my fuel rail.
Any 97+ apparently has the regulator at the pump - in the best most awesome place possible, on top of the pump on the top of the tank. There is no fuel return line I guess.
the heat shield / exhaust wrap trick has been used successfully by some people, I expect it'd work better if you can make sure you get airflow through the inside of it.
3 things you need to do/check:
- NGK's are recommended for later model 4.0's...PN# ZFR5N.....they make a difference
- perform the injector sleeve TSB if you haven't already done so
- try cleaning your cooling system, if crud gets lodged in the jackets of the head then the whole top half of your block will be more prone to heat buildup
^you're missing my point about the plugs, Jeep actually switched their recommended plug once this misfiring issue came about with later model 4.0's....the NGK's were part of the solution to the problem
the injector sleeves are a fiber material
here is the TSB: http://www.wjjeeps.com/tsb/tsb_wj_1803103.pdf
