joe_peters
- Grants Pass, OryGun
Is the "Heat Soak issue" something that happens after a certain number of miles or years on the XJs?
I ask because I'm having a heat soak misfire on my 2000 XJ with 152K. It was fine until this last spring. I have replaced the plugs, coil rail, and I feel like I'm chasing gremlins!!:gonnablow
I keep getting misfire codes, and had not thought to check the injector side of the system....because it was acting like an ignition issue.
I can run it back & forth to work (30 miles almost all highway) and it runs great, but once the airflow drops for a short time (like in normal city driving) it will start to misfire until it is shut off, and cools down again. The temp never goes over 210, but it still starts to miss. It is driving me crazy! :wow:
Tall Shadow :flipoff:
Quick and dirty test: drive it until it is good and hot, park it and open the hood fully.
Wait 20-30 minutes, then start it and see if the misfire is gone or appreciably better.
If it is, don't screw around with heat wrapping an injector--lame A** factory excuse for a fix.
Buy a timer and wire it in so that the efan runs for 3-5 minutes after shutdown. Link to timer here:
http://www.at-fairfax.com/P1786-ELK-960.htm
Numerous makes and models of vehicles come from the factory with this feature built in. It was most likely a "cost-benefit" determination by a Chrysler bean-counter to go with the burrito fix.
