map sensor to throttle body
seigeXJ90
SB Mountains
my hose going from my MAP sensor to my throttle body disappeared.. i can get a new one tomorrow thats not the problem.. however what did it attach to on the throttle body??
it looks like a sort of port there that maybe something is suppose to screw on top of?... that has some gasket maker junk all over it but no tube coming out to plug the hose into... anyone have a pic of the passenger side of their throttle body they can post on here? (in between the TB and the Fuel Rail so I can see what its suppose to look like?
There is a rubber plug that plugs into the throttle body. You have to be careful because there are two holes in the throttle body and you can actually put the plug in upside down if you are not careful. In a pinch I have just stuck a hose in the correct hole with some gasket sealer and run the hose to the MAP. That sounds like what you had going on.
