xjbump
- S.E. Mass, just above the Cape
This is a list of what I have to get rid of. All parts are for Cherokees mostly Pre-96 XJs unless otherwise stated. Obviously some parts fit all years while some are year specific. I'll update as I find more stuff. If you need a pic I should be able to get one.
PLEASE BEFORE YOU POST OR PM CHECK THE THREAD FOR UPDATES AS I CANNOT EDIT THIS LIST BUT I WILL UPDATE AS THINGS ARE SOLD!
Axles/Suspension/Tires/Wheels
1 – 8.25 Rearend – welded 3.55s – from 95’ $50
1 – Ford 9” – Fullsize stock 3.54s – 5 on 5.5 – Not Nodular $150ea
1 – Steering pump & box w/hoses $35
1 - Steering box $25
3 – Rear Driveshafts – All from AW4s - 1 older style and 2 newer style $10ea
1 - Front Driveshaft $25
2 – Prs of front coils from a 00’ & 01’ $10pr
1 - Pr of tires with stock Cherokee 5 star grey rims, size 30x9.5x15 - 1/4" tread $50
Engine/Tranny/Tcases/Accessories
1 - AX5 5spd. & NP231 T-case $150
2 – Computers from 95’ XJs 1- AW4 & 1- AX15 $50ea
1 – Water Pump $10
3 – Starters $20
2 – Water Necks w/Temp Sensors $10
1 – Coolant Res. Bottle $5
2 – Older style washer bottles $5
2 – Newer style washer bottles $5
1 – A/C Comp. Units $15
5 - Diff. size vac. bottles(round/oval) $2
2 – Radiator $25
1 – ABS Booster & Master cylinder 97+ (00’) $25
1 - Poly Gas Tank w/Pump 97+ $30 From a 2.5l
Exterior/Interior/Elec.
Pre96 Parts:
1 – Reargate black $25
6 – Prs of reargate strut arms $10
2 – Hoods – White- paint is good $50, red - paint is bad $25ea
1 – Header Panel w/lights – black $50
1 - Set of Chrome Bezels and Grill, grill has a piece missing off bottom $25
2 - Prs of Marker lights $5pr
1 – Front bumper – 1 chrome $20
1 – Set of F & R bumper brackets $5pr
1 – Pr of Fender Supports w /horn $5
4 – Prs of Wiper Arms w/blades $5pr
1 – Auto T-handle Shifter $5
1 - Grey Arm rest with latch $5
3 – Rearview Mirrors $5
2 – Pass. Door Mirrors $5
2 – Drivers Door Mirror $5
1 - Taillights $15pr
2 – Blower Motors $15ea
1 – Gauge Cluster w/Tach – grey from 94’ has small elec. Plug on back $15 1 – Temp. Selector Switch $10
A ton of Pre96 Dash switches & Marker Lights $5ea or 2 for $8
97-01 Parts:
1 - Complete Nose From a 99' Cherokee fits 97-01 $300 Includes: Hood, fenders, header panel and front bumper
- Hood $50
- Fenders and Inners $50ea
- Header Panel w/all lights & wires $200
- Front bumper & endcaps $25
1 – Pr of Air Bags w/sensor unit D & P 97+ (99’) $100
1 – Headlight Switch 97+ $10
1 – Front bumper endcaps and center plastic pieces - grey 97+ $30
1 - Rear Bumper black & endcaps grey 97+ $25
2 – Center console trim- Drk Grey 97+ $10
1 – Grills 97+ - Painted Black w/chrome centers $20
1 – Drivers Rear door power window motor & assembly 97+ (00’) $20
1 – Drivers side F & R door handles w/power lock, rods & latch 97+ $20
1 - Rear Hatch Black 97+ $75
1 - Rear Flares Grey/Unpainted 97+ $10
1 - Steering Column w/Airbag & Key 97+ $30
1 - Center Console $20
1 - Headliner w/Soundbar $25
1 - Pass. Frt Seat and rear from 97+ 2Dr. grey $25
Dark grey Int. Pieces from a 99' 2dr. $5+
1 – Water Pump $10
3 – Starters $20
2 – Radiator $25
Pre96 Parts:
97-01 Parts:
- Hood $50
