RWKHausSupply
- yorba linda, Cali
ALL OF THIS IS NEW in box and with with manufacture warranty.
EVERYTHING IS 1ST QUALITY NOT BLEMS OR REJECTS
All pricing is shipped to your door most Anywhere.
if you buy more then one item (ANY OTHER ITEM) then you will SAVE ABOUT 10-15$ PER ITEM OVER 1!
ECTED Elect lockers-
AG 545013 M35 27spl 3.54&UP ECTED ELEC LOCKER/POSI, (IN $575
AG 545014 M35 30spl 3.31&DOWN ECTED ELEC LOCKER/POSI $500
AG 545016 D30 27spl 3.54 & DOWN ECTED ELEC LOCKER/POSI, $590
ARB Air Locker -
ARBRD105 dana 35 SUPER 30spline 3.54 & UP AIR LOCKER $735
Detroit Locker -
DET187C-145A 8.8" FORD,87 &UP 31spl, 7/8" CASE $575
DET187S-17B 9" FORD 31spl DETROIT LOCKER, 1.785"_JRNL $490
DET225S-193A D60 40spl 4.56 & UP DETROIT LOCKER $558
DET225S-193B D60 40spl 4.10 & DOWN DETROIT LOCKER $558
DET225S-19A D60 30spl 4.56 & UP DETROIT LOCKER $537
DET162S-60A D30 3.54 & DOWN DETROIT LOCKE $480
Dana Spicer Items -
DS 707469 D60 Ball Joints,Top&Bottom (ONE SIDE) DODGE+FORD, UP to 1999 $120 for all 4 total 2 sides
Eaton -
EAT19737 D60 4.56 & UP 30spl E-LOCKER $630
TRUE GM Gears (not aftermarket) -
GM 14-456 14T 10.5'' GM 4.56 R&P (fits_4.56_&_up_CSE) (OEM) $180
GM 14-513 14T 10.5'' GM 5.13 R&P (fits_4.56_&_up_CSE) (OEM) $190
Yukon Gear parts -
YC D706008 D30 STD CASE, 3.73 & UP, 1.943''_tall $50
YC D706025 D44 30spl STD CASE, 3.92 & UP, 2-3/8'' TALL $52
Yukon Gears -
YG C9.25-456 9.25'' CHY 4.56 '09&DWN,some'10 R&P(NEEDS_NOTCHED_X/P_C/CLIPS) $200
YG D30S-373TJ D30 SHORT 3.73 R&P STD ROTATION w/ C/SLEEVE(R&P ONLY) TJ $140
YG D30S-411TJ D30 SHORT 4.10 R&P STD ROTATION w/ C/SLEEVE(R&P ONLY) TJ $140
YG D30S-456TJ D30 SHORT 4.56 R&P STD ROT w/ C/SLEEVE(R&P ONLY) TJ $140
YG D44-488 D44 4.89 R&P $179
YG D50R-456R D50 4.56 REV R&P $107
YG D50R-513R D50 5.13 REV R&P $107
YG D50R-538R D50 5.38 REV R&P $107
YG F10.25-411L 10.25'' FORD 4.10 R&P for LONG_YOKE_ONLY,_93&UP $146
YG F10.25-430L 10.25'' FORD 4.30 R&P for LONG_YOKE_ONLY,_93&UP $146
YG F10.25-456L 10.25'' FORD 4.56 R&P for LONG_YOKE_ONLY,_93&UP $149
YG F10.25-488L 10.25'' FORD 4.88 R&P for LONG_YOKE_ONLY,_93&UP $146
YG F10.25-538L 10.25'' FORD 5.38 R&P for LONG_YOKE_ONLY,_93&UP $146
YG F10.5-355-31 10.5'' FORD 3.55 R&P '99-'10 w/ 31spl PINION $155
YG F10.5-411-31 10.5'' FORD 4.10 R&P '99-'10 w/ 31spl PINION $155
YG F10.5-488-31 10.5'' FORD 4.88 R&P '99-'10 w/ 31spl PINION $155
YG F8.8R-488R 8.8'' FORD 4.88 REV R&P Currie High Pinion also - $135
YG F8.8R-513R 8.8'' FORD 5.13 REV R&P Currie High Pinion also - $129
YG F9.75-411 9.75'' FORD 4.10 R&P '10&DWN (may_use_SPECIAL_pin_nut!!_CHECK_THREADS!!) $146
YG F9.75-456 9.75'' FORD 4.56 R&P '10&DWN may_use_SPECIAL_pin_nut!!_CHECK_THREADS!!) $155
YG F9.75-488 9.75'' FORD 4.88 R&P '10&DWN (may_use_SPECIAL_pin_nut!!_CHECK_THREADS!!) $165
YG F9.75-513 9.75'' FORD 5.13 R&P '10&DWN (may_use_SPECIAL_pin_nut!!_CHECK_THREADS!!) $140
YG F9-456 9'' FORD 4.56 R&P $142
YG F9-486 9'' FORD 4.86 R&P $142
YG F9-513 9'' FORD 5.13 R&P $142
YG GM14T-373 14T 10.5'' GM 3.73 R&P $185
YG GM14T-411 14T 10.5'' GM 4.11 R&P $185
YG GM14T-456 14T 10.5'' GM 4.56 R&P $180
YG GM14T-456T 14T 10.5'' GM4.56 THICK R&P (fits_4.10_&_DWN_CSE) $180
YG GM14T-488T 14T 10.5'' GM 4.88 THICK R&P (fits_4.10_&_DWN_CSE) $175
YG GM14T-513T 14T 10.5'' GM 5.13 THICK R&P (fits_4.10_&_DWN_CSE) $152
YG GM8.5-513 8.5'' GM 5.13 R&P (NEEDS_NOTCHED_X/P) (_NO_ABS_PROVISION) $125
YG GM8.5-538 8.5'' GM 5.38 R&P (NEEDS_NOTCHED_X/P) $125
YG M20-456 M20 4.56 R&P $170
YG M20-488 M20 4.88 R&P $142
YG M35R-488R M35IFS 4.56 REV R&P $75
YG T100-529 T100 & TACOMA 5.29 R&P w/o_LOCKER $89
YG T7.5R-456R 7.5'' TOY 4.56 REV R&P for TACOMA & T100 IFS FRONT $107
YG T7.5R-529R 7.5'' TOY 5.29 REV R&P for TACOMA & T100 IFS FRONT $67
YG T8-456 8'' TOY 4.56 R&P $124
SPOOLS -
YP F9PS-1 9'' FORD HD 6061 ALUMINUM pinion support, DAYTONA, PURPLE $73
YP F9PS-1-CLEAR 9'' FORD HD 6061 ALUMINUM pinion support, DAYTONA,PLAIN-SILVER $72
YP F9PS-4 9'' ''N'' DAYTONA style NODULAR IRON pinion support (incl._races) $67
YP FSD44-3-30DN D44 3.73 & DOWN 30spl SPOOL, STEEL $108
YP FSD44-4-30UP D44 3.92 & UP 30spl SPOOL, STEEL $130
YP FSF9-28-LW 9'' FORD 28spl LIGHT WEIGHT STEEL,2-1/8''DECK,1.785'' JRNL $97
YP FSF9-31-LW 9'' FORD 31spl LIGHT WEIGHT STEEL,2-1/8''DECK,1.785''JRNL $109
YP FSF9-33 9'' FORD 33spl STEEL SPOOL,2-1/4''DECK,1.785''JRNL_ 45degree $130
YP FSF9-35 9'' FORD 35spl SPOOL 30deg(EXCL_M.WLMS)2-3/16''DECK,2''JRNL $97
YP FSF9-35SMALL 9'' FORD 35spl STEEL(fits_2.8''_&_3.0''_cases),1.785''JRNL $63
YP MINSD44-30 D44 30SPL MINI SPOOL $70
YUKON SUPER JOINTS WITH LIFETIME WARRANTY!
YP SJ-297X-201 (1) D44 760X EXTRA-HD M43400 CHROME-MOLY SUPER-JOINT 297X $135
YP SJ-297X-202 (2) D44 760X EXTRA-HD M43400 CHROME-MOLY SUPER-JOINT 297X $247
USA STANDARD GEARS -
ZG D44RS-513RUB JK RUBICON FRONT D44 REV 5.13 THICK R&P $133
ZG GM8.5-411 8.5'' GM 4.11 R&P $125
ZG GM8.5-488 8.5'' GM 4.88 R&P $121
ZG GM8.5-513 8.5'' GM 5.13 R&P $125
There ya go.
ONCE THEY ARE GONE (ONLY 1 TO 3 OF SOME AND A FEW HUNDRED OF OTHERS) THEN THEY ARE GONE!
Email me for this pricing.
robert
[email protected]
714-875-2414
ARB Air Locker -
Detroit Locker -
Dana Spicer Items -
Eaton -
Yukon Gear parts -
Yukon Gears -
SPOOLS -
There ya go.
robert
[email protected]
714-875-2414
