- Hammertown, USA
I would call the high-volume oil pump necessary.
If bearing clearances are correct a high volume is not necessary, if it's built loose they can be. Just like in the SBC/BBC Chevy world your engine is built correctly you don't need them unless running an oil cooler or remote filters. If anything put a stronger relief spring in to bump pressures at higher rpms. Unless someone can show me how a properly set up stock pump is inadequate for a low rpm 4.0.
Not to many vendors sell parts for one! Has anybody had dealings with http://www.cleggengine.com/stroker-kits/jeep-4-0-stroker-kits.html as they seem to have good prices?
Pistons seem to be the hardest to find.
Not really,I used these...
https://www.summitracing.com/parts/uem-ic944-020
Used
These rods...
http://www.shop.505performance.com/product.sc?productId=311&categoryId=23
Russ Pottenger
Bishop-Buehl Racing Engines
531 N. Lyall Avenue
West Covina, California 91790
Work (626) 967-1000
Cell (626) 673-2203
Email/PayPal: [email protected]
I actually started out looking for some H-beam rods as those have been my favorites to use in the past!
Russ's current piston and rod offerings.
