hadAjeep said:
Ok, I don't even have an XJ yet but the kit I'm looking at is the RE 6130 so I can run 33's. It doesn't say long arm so I'm guessing it's not. My friends MJ has a 2-3 inch skyjacker lift with new springs in the front and new control arms. It rides rougher on the trails than my 3/4 ton Ram. Granted he uses the skyjacker cheapo shocks and I've got a T-REX suspension. So the harsh ride is the short arms huh? Would better shocks help? Man did I open a can o worms here. Thanks for the info so far.
A harsh ride can come from any number of things. Some people even look at the tire pressure on the side of a tire (which is used for that tire's weight rating) and fill them to that pressure.......which is usually way to much and will give a harsh ride. Some shocks are just too stiff, or are poor quality, and give a harsh ride all by themselves. Also, many rear spring packs are just too stiff, with too stiff a spring rate or add-a-leafs or too much friction between the individual leaves.
On a tall lift, starting probably between 3-4", the control arm angles are getting steep enough to effect the ride, and it gets worse as the lift increases. Because the control arms are pointed down so much the axle/tire must move forward as well as upwards when hitting a bump, and this increases the harshness. Flatening out the arm angles, regardless of how it's accomplished, will improve the ride.
Someone asked about unloading. Unloading is when the front of the rig floats up on steep climbs due to weight transfer, leaving the front with much less traction and putting the rig in an unstable position. One reason long arms tend to increase unloading is that the weight of the front axle/tires/wheels is working (think pulling down) on the rig at a point further back on the frame. Obviously, the further forward weight is distributed the more it will pull down on the front of the vehicle, and more weight forward is better on steep climbs. Since the weight of the front axle assembly is tranfserred to the body through the control arm mounts to the frame, the further back the mounts are the less effect the front axle weight has to work/pull down on the front of the rig. Of course, if the shocks are fully extended the weight will transfer through the shocks, but if you're nose is pointing upward and the shocks are fully extended you are already feeling the effects of unloading. A limiting strap can be used to transfer the weight of the axle assembly to the body at a much more forward location, and limiting straps work well to decrease unloading and to increase steep climbing ability. However, a balance has to be reached in determining the length of the limiting straps between axle articulation, climbing, and flat out runnning through the desert. Ideally, there would be three available limiting strap lengths, short for climbing, longer for articulation, and longest for the most travel when running flat out. Unfortunately, there's no real way to do that, so we have to compromise. Some competition rigs deal with this issue by using limiting straps set for trail work, and then use the winch attached to the front axle to pull down on steep climbs.
BTW, if a lift kit does not say "long arm", it's a short arm kit.
