hey john, your jeep sounds like something I like, can you send me pictures of your rig, I would like you to give me more info on the chromo axle and what not.
My 92 is pretty basic with a lot of junk yard parts and home brew stuff. I tried to spend as little as possible on it but still end up with something that wheels really well. Low and armored is the theme. Most of what I did you can duplicate with persistence in the junk yard and a welder or friend that has one. I have posted most of these mods so if you list out threads started by me you will find the details. The armor came first for the most part and I am very glad I did it that way.
Aussies front and rear, bastard pack rear 3/8ths center pin (grade 8 bolt), longer rear shackles, 1" lift block (its 7 inches long with 6 deg of taper and radiused on the top, machined it myself, been running it for two years and with no problems) T-Bird springs up front with a couple extra XJ coil isolators to trim the lift, XJ D44 rear, HP D30 front, RE track bar and track bar mount, tie rod has a bar rosette welded inside it and is boxed on the outside with angle iron. AJ's rails, Rusty's oil/trans skid, Rusty's diff skids, factory gas and t case skids, factory rear hitch, factory front tow hooks, boxed lower control arm mounts, raised rear shock mounts, armored muffler, gusseted passenger side upper axle mount. Alloy USA front axles, full circlips retaining the caps on the front shafts, SYE (PORC), XJ front shaft used in the rear, armored frame rails, XJ dual diaphragm booster (and pedal box), aftermarket front outboard axle seals, hockey puck bump stops front and stacked & welded box tube to space the rear bump stops down, F250 rear sway bar links used as quick disconnects (wing nut on top, hitch pin on bottom), various Monroe truck shocks (14" travel front, 13" rear), Mix of rustys (Junk) and Terra Flex (excellent) adjustable front control arms. Air intake is through the firewall into the area just in front of the windshield. Modified factory swing out spare tire carrier to raise the tire 7" with a built in skid to keep the tire from hanging up on higher ledge drops.
90% of the junk yard and home brew "how too" I found by searching in the modified tech forum.
John
